Looking into the Comet KVM but all of the old servers in my rack only have vga video outputs. Has anyone had success with a HDMI->VGA adapter with the Comet KVM?
No experience with VGA but I have been using a DisplayPort to HDMI Adapter with no problem at all.
I have actually just seen a video on the tube with a guy using a POWERED VGA TO HDMI adapter (and make sure it is not the other way round) with no issues.
I have tested it. It works. It's a VGA TO HDMI adapter
Would you be willing to share which adapter works for you?
I can confirm that the StarTech VGA2HDU (powered VGA to HDMI) does not work.
It might be related to the fact that your motherboard can only output a certain specific resolution. You have to first confirm whether it is this problem. You can use the command dmesg| grep 6911 to see what resolution the motherboard is trying to input into COMET.
This one worked for me:
Cheers.
Worked for me as well!
