Has support for ZeroTier been dropped from Puli 4.3.2 beta firmware? I notice that it does not exist under “äpplications” yet the 4.x docs still says that zerotier is supported on v4.x firmware. Please confirm? I can run zerotier from a AR-150 manually and it works fine, so I doubt resources is an issue.
puli is not enough to run zerotier well, you can use it by dynamically installing gl-sdk4-zerotier and gl-sdk4-ui-zerotierview in the software repository.
Correct me if I am wrong, but I would need to down grade the firmware? I cant seem to get the repo’s to work using firmware 4.3.2.
