Have I bricked my AR750?
I downloaded firmware 3.0-1011 from the support page and applied the update. Everything went smoothly and I was able to log back in.
When attempting to update the opkg lists, I was given an error saying wrong signature file. I thought the easiest way to resolve this would be a factory reset so held in the button for 10+seconds. Now it wont boot.
I power up the device aand all the power light stays on but the 2 other LED’s flicker on for a fraction of a second before going out. this happens twice and then all I get is the power light on solid.
Can I restore functionality and get things running again?
LMAO.
Just found this little snippet in the readme.txt.
’ “clean” contains a clean firmware with minimal packages, with LuCI installed, wifi is disabled by default. ’
Fingers crossed that is just it
Please try the latest testing firmware.
If you want to build a clean firmware, you can include the files folder. GitHub - gl-inet/openwrt-files
Thanks loads. Appreciated.
what’s the etiquette now? Do I edit the title to say solved? or delete thread?
Please don’t delete thread. You can ticked the solution.
