Help appreciated: Flint 2/MT6000 as Wirequard VPN Client to Fritzbox
Hello everyone,
my setup is:
At home -> Fritzbox with a properly set up Wireguard connection
travelling -> MT6000 with the proper config file installed (green light / working VPN to Fritzbox)
Problem on the MT6000:
I have full internet connectivity accross all clients with the VPN disabled. Once I enable the Wireguard client VPN, the connection light turns green, but I loose internet connection on all clients.
I have tried to use the exact same config file on my iPhone... works flawlessly, so I doubt it can be a faulty configuration on the side of the Fritzbox.
I presume I have some sort of DNS issue on the Gli Router, but I cannot find a functioning instruction on how to resolve the issue. Can anyone please help?
Thanks
Steve
Please PM me Travel router issue syslog with WireGuard Client enabled.
