Hi, recently I started to configure my GL-Inet B1300 AP but in my home I have my router with the following IP: 192.168.1.1 and the AP has 192.168.8.1 so I changed my GL-Inet AP IP to 192.168.1.2 but when I try to go to the console (putting 192.168.1.2) in the screen appears the following message:
Forbidden
You don’t have permission to access this resource in /cgi-bin/
Now, pls disconnect B1300 from your main router, connect to its wifi or lan and you should be able to access the web panel at 192.168.1.2. If not, press and hold the reset button for 10 seconds to reset it and try again.
Here the error (I’m disconnected off the network because as far as I know my mac will find 2 routers with the same IP, this AP and my router so it will not know where it has to go and will collapse)
