I have a mesh network (192.168.1.1-255 which I will call MeshNet) at home and I have bought a GL-MT1300 Beryl router (LAN 192.168.8.1 which I will call BerylNet) to help me with a Wireguard VPN Client, it is a device on my MeshNet.
I have an Nvidia Shield on BerylNet which can stream via the VPN just fine but I would like it to be able to access a NAS on MeshNet.
MeshNet consists of 2 nodes 192.168.1.1 and 192.168.1.2 and it’s DHCP server gives out addresses in the range 192.168.1.32-254. It’s setup and configuration are quite tightly locked down, effectively an app which just figures it all out and I have to say seems to do a good job. I believe it cannot be set to AP mode but I can set the ‘WAN Connection Type’ to DHCP, Static IP, PPPOE or Bridge, it is currently set to DHCP.
If it helps I could make MeshNet ‘a device’ on BerylNet.
Can I get the 2 Net’s to communicate with each other?
