Hello everyone,
I recently purchased the Slate AX router to complement my current setup. I cannot modify the settings on my ISP-provided router, so I bought the Slate AX to configure it with TorGuard VPN (with a dedicated IP) and AdGuard Home for network-wide ad blocking.
My Setup:
• ISP Router: Cannot be modified.
• Slate AX: Configured as a secondary router connected to the ISP router.
• TorGuard VPN: Configured with OpenVPN/WireGuard, using 1.1.1.1 as the DNS server from the TorGuard config file.
• AdGuard Home: Enabled and working on the Slate AX.
Questions:
- DNS Settings:
• Should I use 1.1.1.1 (Cloudflare DNS) as configured in the TorGuard VPN config file, or should I replace it with the Slate AX’s local router address (192.168.8.1)?
• What is the best way to ensure that AdGuard Home filters all DNS requests while still routing everything through the TorGuard VPN for privacy?
- AdGuard Home Message:
• I keep seeing the following message in the DNS settings of the Slate AX:
“AdGuard Home is enabled and this router will use the DNS server provided by AdGuard Home as the custom DNS server. The DNS server settings will not work.”
Can someone clarify what this means for my DNS settings and how to manage upstream DNS servers effectively?
- Optimal Settings:
• What are the best settings to use in the Slate AX to ensure:
• AdGuard Home filters all DNS requests.
• TorGuard VPN handles all traffic, including DNS, without leaks.
• Should “Block Non-VPN Traffic” be enabled, and how does it interact with AdGuard Home?
Additional Context:
• I want to ensure no DNS leaks and complete ad-blocking across all devices in my network.
• I use the VPN for privacy, a dedicated IP, and bypassing regional restrictions.
I’d appreciate any insights, best practices, or step-by-step guides for this configuration. Let me know if I need to provide additional details.
Thank you!
Mike
