HELP NEEDED WPA3 issues
Can't connect my laptop to WPA3 of GL router.
I dunno is there is an issue with laptop or router but other devices connects.
Beryl AX
Laptop config:
System:
Kernel: 6.5.0-17-generic x86_64 bits: 64 compiler: N/A
Desktop: Cinnamon 6.0.4 tk: GTK 3.24.33 wm: muffin vt: 7 dm: LightDM 1.30.0
Distro: Linux Mint 21 base: Ubuntu 22.04 jammy
Machine:
Type: Desktop  System: ASUS
product: [edited] v: [edited] serial: [edited]
Mobo: ASUSTeK model: ROG STRIX B650E-F GAMING WIFI v: Rev 1.xx
serial: [edited] UEFI: American Megatrends v: 1409
date: 04/20/2023
Battery:
Device-1: hidpp_battery_0 model: Logitech K520 serial: [edited]
charge: 70% (should be ignored) rechargeable: yes status: Discharging
Device-2: hidpp_battery_1 model: Logitech M310 serial: [edited]
charge: 55% (should be ignored) rechargeable: yes status: Discharging
CPU:
Info: 12-core model: AMD Ryzen 9 7900X bits: 64 type: MT MCP smt: enabled
arch: Zen 3 rev: 2 cache: L1: 768 KiB L2: 12 MiB L3: 64 MiB
Speed (MHz): avg: 768 high: 4972 min/max: 400/5733
cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400 8: 400
9: 400 10: 400 11: 400 12: 400 13: 400 14: 400 15: 4680
16: 400 17: 400 18: 400 19: 400 20: 400 21: 400 22: 400
23: 4972 24: 400
bogomips: 225591
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
Graphics:
Device-1: NVIDIA GA106 [GeForce RTX 3060 Lite Hash Rate] vendor: ZOTAC
driver: nvidia v: 535.154.05 pcie: speed: 2.5 GT/s lanes: 16
ports: active: none off: HDMI-A-2 empty: DP-2,DP-3,DP-4 bus-ID: 01:00.0
chip-ID: 10de:2504 class-ID: 0300
Device-2: AMD vendor: ASUSTeK driver: amdgpu v: kernel
pcie: speed: 16 GT/s lanes: 16 ports: active: none empty: DP-1,HDMI-A-1
bus-ID: 0b:00.0 chip-ID: 1002:164e class-ID: 0300
Display: x11 server: X.Org v: 1.21.1.4 driver: X:
loaded: amdgpu,ati,nvidia unloaded: fbdev,modesetting,nouveau,vesa
gpu: nvidia,amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 69 s-size: 707x392mm (27.8x15.4")
s-diag: 808mm (31.8")
Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 70
size: 697x392mm (27.4x15.4") diag: 800mm (31.5")
OpenGL: renderer: NVIDIA GeForce RTX 3060/PCIe/SSE2
v: 4.6.0 NVIDIA 535.154.05 direct render: Yes
Audio:
Device-1: NVIDIA vendor: ZOTAC driver: snd_hda_intel v: kernel
pcie: speed: 16 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:228e class-ID: 0403
Device-2: AMD vendor: ASUSTeK driver: snd_hda_intel v: kernel
pcie: speed: 16 GT/s lanes: 16 bus-ID: 0b:00.1 chip-ID: 1002:1640 class-ID: 0403
Device-3: ASUSTek USB Audio type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-6:3 chip-ID: 0b05:1a52
class-ID: 0300
Sound Server-1: ALSA v: k6.5.0-17-generic running: yes
Sound Server-2: PulseAudio v: 15.99.1 running: yes
Sound Server-3: PipeWire v: 0.3.48 running: yes
Network:
Device-1: Intel Wi-Fi 6 AX210/AX211/AX411 160MHz driver: iwlwifi v: kernel
pcie: speed: 5 GT/s lanes: 1 bus-ID: 05:00.0 chip-ID: 8086:2725
class-ID: 0280
IF: wlp5s0 state: up mac: [edited]
Device-2: Intel Ethernet I225-V vendor: ASUSTeK driver: igc v: kernel
pcie: speed: 5 GT/s lanes: 1 port: N/A bus-ID: 07:00.0 chip-ID: 8086:15f3
class-ID: 0200
IF: eno1 state: down mac: [edited]
Bluetooth:
Device-1: MediaTek Wireless_Device type: USB driver: btusb v: 0.8
bus-ID: 1-11:7 chip-ID: 0e8d:0608 class-ID: e001 serial: [edited]
Report: hciconfig ID: hci0 rfk-id: 0 state: up address: [edited]
bt-v: 3.0 lmp-v: 5.2 sub-v: 2211 hci-v: 5.2 rev: 1021
Drives:
Local Storage: total: 2.75 TiB used: 87.48 GiB (3.1%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 980 PRO 2TB size: 1.82 TiB
speed: 63.2 Gb/s lanes: 4 type: SSD serial: [edited] rev: 5B2QGXA7
temp: 26.9 C scheme: GPT
ID-2: /dev/sda model: T-FORCE 1TB size: 953.87 GiB speed: 6.0 Gb/s
type: SSD serial: [edited] rev: LB.5 scheme: GPT
Partition:
ID-1: / size: 937.33 GiB used: 87.48 GiB (9.3%) fs: ext4 dev: /dev/sda3
ID-2: /boot/efi size: 512 MiB used: 6.1 MiB (1.2%) fs: vfat
dev: /dev/sda2
Swap:
ID-1: swap-1 type: file size: 2 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
Sensors:
System Temperatures: cpu: N/A mobo: N/A
Fan Speeds (RPM): N/A
GPU: device: nvidia screen: :0.0 temp: 34 C fan: 0%
device: amdgpu temp: 41.0 C
Repos:
Packages: apt: 2537
No active apt repos in: /etc/apt/sources.list
Active apt repos in: /etc/apt/sources.list.d/cappelikan-ppa-jammy.list:
1: deb [arch=amd64 signed-by=/etc/apt/keyrings/cappelikan-ppa-jammy.gpg] https://ppa.launchpadcontent.net/cappelikan/ppa/ubuntu jammy main
Active apt repos in: /etc/apt/sources.list.d/official-package-repositories.list:
1: deb http://packages.linuxmint.com virginia main upstream import backport
2: deb http://archive.ubuntu.com/ubuntu jammy main restricted universe multiverse
3: deb http://archive.ubuntu.com/ubuntu jammy-updates main restricted universe multiverse
4: deb http://archive.ubuntu.com/ubuntu jammy-backports main restricted universe multiverse
5: deb http://security.ubuntu.com/ubuntu/ jammy-security main restricted universe multiverse
Info:
Processes: 465 Uptime: 10m wakeups: 5 Memory: 30.49 GiB
used: 2.25 GiB (7.4%) Init: systemd v: 249 runlevel: 5
Compilers: gcc: 11.4.0 alt: 11/12
Shell: Bash v: 5.1.16 running-in: xfce4-terminal
inxi: 3.3.13
Network Interfaces Status:
0: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
1: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
lo        no wireless extensions.
eno1      no wireless extensions.
wlp5s0    IEEE 802.11  ESSID:"Gl-test-router"
Mode: Managed  Frequency: 5.6 GHz  Access Point: 64:97:14:26:AC:07
Bit Rate=1.9215 Gb/s   Tx-Power=22 dBm
Retry short limit: 7   RTS thr: off   Fragment thr: off
Power Management: off
Link Quality=61/70  Signal level=-49 dBm
Rx invalid nwid: 0  Rx invalid crypt: 0  Rx invalid frag: 0
Tx excessive retries: 0  Invalid misc: 255   Missed beacon: 0
SecureBoot disabled
If other devices are connecting, so the problem is not on the router.
I'm using WPA3 by a long time on Flint 2 and Beryl AX with no problem.
