Help on native windows l2tp client on the lan
Hi everyone,
I’ve been trying the products for a while now,
I set up a router in simple configuration.
ISP Router (192.168.5.1) → GL-SFT1200 (192.168.8.1) → Lan (192.168.8.0/24).
no enable for vpn server on router GL-SFT1200, not needed,
only browsing for a few PCs
after this setup, the native windows l2tp client on the lan (192.168.8.0/24) fails to connect to the remote corporate l2tp server. returns a nat problem.
no problem if instead my l2tp client is in the ISP router LAn (192.168.5.0/24).
is there a setting on the GLI that blocks the use of l2tp clients in the lan ? and how to disable it?
I tried enabling the VPN Policies, or putting the client in the DMZ to avoid some blocking rules. but without success
GL-SFT1200 Fw:3.215
any suggestions?
Thank you so much
This may be the problem:
http://sigkillit.com/2021/04/07/l2tp-behind-double-nat/
Thanks wcs2228,
what a fool i am…
I forgot this problem in windows, I’ll try right away… thanks for reminding me! :slight_smile:
I’ll let you know if resolved
