hi, @Satyam500160
recently we discuss regarding GL-X3000NR with jio sim in india.
currently i use ZTE MC801A with jio 5G sim. but problem is limited speed (less than 1mbps) on both windows pc if connect via ethernet cable. But, if i connect via wifi on windows get full speed.
So, can you connect GL-X3000NR with windows pc via ethernet cable with jio sim and check download speed test with this link : https://test2.fibertelecom.it/1GB.zip
Are you face any speed limit issue?
Thank you,
Check your ethernet connection handshake between router and windows on your windows network management. Because sometimes 1gbps handshake fails and downgrade to 10mbps speed.
No problem with any lan speed issue. i already do different test. and final conclusion is if connect via Ethernet with ZTE 5G CPE than get slow download speed 300kbps-600kbps when download any file, but speed test is fine.
