I’m trying to set up my GL-AR750S-EXT with the OpenVPN VPN connection established through my router (Netgear Nighthawk CAX30). I set up my VPN using the Netgear instructions and from what I can see, it is working as I’m able to connect to this VPN from my windows computer.
I tried uploading the same configuration zip file (for windows, non-windows or smartphone) through the GL.iNet admin panel → OpenVPN Client → and uploading the file but it’s giving me errors. i’m attaching screenshots as it’s probably easier to understand by looking at the screenshots.
Could you please help me in understanding what I need to do so I can have the VPN set up correctly on the GL-AR750S-EXT.
Thank you for all your help!
