Help setting up travel router.
Hi Guys! I just recently bought 2 GL Inet routers which is the opal (server) and the beryl AX (Client). I am having some trouble connecting to my client even though I already set-up the port forwarding in my ISP (I'm using wireguard).
my Beryl AX is stuck on **"the client is starting. please wait.." (I am connected to both different networks). would you guys know any other possible reason why it stuck?
there is a log in my Beryl saying:
Sat Mar 8 16:18:41 2025 user.notice firewall: Reloading firewall due to ifdown of wgclient ()
Sat Mar 8 16:19:40 2025 daemon.notice netifd: Interface 'wgclient' is setting up now
Sat Mar 8 16:21:27 2025 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=REKEY-GIVEUP SHLVL=1 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Sat Mar 8 16:21:27 2025 daemon.notice netifd: Interface 'wgclient' is now down
Sat Mar 8 16:21:27 2025 daemon.notice netifd: Interface 'wgclient' is setting up now
Sat Mar 8 16:21:28 2025 user.notice firewall: Reloading firewall due to ifdown of wgclient ()
Sat Mar 8 16:21:28 2025 daemon.notice netifd: Interface 'wgclient' is now down
Sat Mar 8 16:22:06 2025 daemon.notice netifd: Interface 'wgclient' is setting up now
Sat Mar 8 16:23:52 2025 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=REKEY-GIVEUP SHLVL=1 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Sat Mar 8 16:23:52 2025 daemon.notice netifd: Interface 'wgclient' is now down
Sat Mar 8 16:23:52 2025 daemon.notice netifd: Interface 'wgclient' is setting up now
Sat Mar 8 16:23:52 2025 user.notice firewall: Reloading firewall due to ifdown of wgclient ()
Sat Mar 8 16:25:41 2025 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=REKEY-GIVEUP SHLVL=1 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Sat Mar 8 16:25:41 2025 daemon.notice netifd: Interface 'wgclient' is now down
Sat Mar 8 16:25:41 2025 daemon.notice netifd: Interface 'wgclient' is setting up now
Sat Mar 8 16:25:41 2025 user.notice firewall: Reloading firewall due to ifdown of wgclient ()
Sat Mar 8 16:26:02 2025 daemon.notice netifd: Interface 'wgclient' is now down
Sat Mar 8 16:26:02 2025 user.notice firewall: Reloading firewall due to ifdown of wgclient ()
Sat Mar 8 16:34:48 2025 daemon.notice netifd: Interface 'wgclient' is setting up now
Please check How to troubleshoot WireGuard
I’m new to GL routers, but my first check would be to test if a remote pc or laptop could connect to WireGuard server on the home router. If it has issues, then your travel router has no chance of working. Once you confirm that the WireGuard vpn can connect, move on to the travel router.
To do this, download the WireGuard configuration file and install the WG client on a pc.
