Hello i have an VERY frustrating issues with this trivial things.
Ax1800 Firmware Version4.2.0
I need to run automatic startup two binary package, qbittorrent and Torserver.
So i go to owrt manual about /init.d/ scripts Owrt site and make my own script and put it in to /init.d/ dir and in console enter: /overlay/upper/etc/init.d/torrserver enable
and chmod +x for scripts to
from console i manually run script by
/overlay/upper/etc/init.d/torrserver start
/overlay/upper/etc/init.d/qbittorrent start
And it works well, no problem, service is start and work.
But when i reboot router, its begin a problem, only qbittorren startup, torserver don’t startup. And in some case when i try edit script by add :
#start torrserver
/overlay/sbin/TorrServer "&"
or "exit 0"
the router begin make my brain and don’t reboot, or adguard home don’t startup after hard power off, and i don’t have internet working at all because dns.
So can you help me make it work?
I try to make autostart from luci> Startup> [Local Startup] меню by add full path to my binare
like this:
Put your custom commands here that should be executed once
the system init finished. By default this file does nothing.
. /lib/functions/gl_util.sh
remount_ubifs/overlay/sbin/TorrServer
/overlay/sbin/qbittorrentexit 0
but its again only one service run not both
That’s my script
#!/bin/sh /etc/rc.common
START=97
STOP=01
PROG=/overlay/sbin/TorrServer
start() {
# start torrserver
/overlay/sbin/TorrServer &
stop() {
# stop torrserver
killall TorrServer
START=89
STOP=01
PROG=/overlay/sbin/qbittorrent
start() {
# start qbittorrent
stop() {
# stop qbittorrent
killall qbittorrent
log file
logread.zip (20.9 KB)
