I have a Beryl and have imported an OpenVPN client config from Getflix.com.au. I have used this config before in tunnelblick on the Mac and in the official OpenVPN client for iOS and it works fine as well as in Ubuntu, however, when using it in the router’s firmware I am unable to connect. I have tried a few different configuration profiles (TCP 443, UDP 443) and they all do not work. Config directions can be found here for a different OpenWRT-based router which I used as a reference: Full VPN Setup for ASUS Routers: OpenVPN - Getflix Smart DNS & VPN Knowledge Base . Any help would be appreciated.
In its ovpn file, pls check if they have compress lzo. If yes, pls comment out this line or just delete this line. Then upload to the rotuer again.
