HELP: Unable to connect to VPN client. Included logs
I am trying to set up my Slate AX 1800 client router and am unable to connect to my Flint AX 1800 server router. I am also on the most recent upgrade and not sure if that has something to do with me not being able to connect the two.
I am trying to use Wiregaurd and have already set up port forwarding from my ISP router back at home.
Can someone please take a look at these logs and let me know if they are able to tell what is going wrong?
Thu Nov 9 23:08:47 2023 daemon.notice netifd: wgclient (22300): * Rule ‘out_conn_mark_restore’\nThu Nov 9 23:08:47 2023 daemon.notice netifd: wgclient (22300): * Zone ‘lan’\nThu Nov 9 23:08:47 2023 daemon.notice netifd: wgclient (22300): * Zone ‘wan’\nThu Nov 9 23:08:47 2023 daemon.notice netifd: wgclient (22300): * Zone ‘guest’\nThu Nov 9 23:08:47 2023 daemon.notice netifd: wgclient (22300): * Zone ‘wgclient’\nThu Nov 9 23:08:47 2023 daemon.notice netifd: wgclient (22300): * Set tcp_ecn to off\nThu Nov 9 23:08:47 2023 daemon.notice netifd: wgclient (22300): * Set tcp_syncookies to on\nThu Nov 9 23:08:47 2023 daemon.notice netifd: wgclient (22300): * Set tcp_window_scaling to on\nThu Nov 9 23:08:47 2023 daemon.notice netifd: wgclient (22300): * Running script ‘/etc/firewall.nat6’\nThu Nov 9 23:08:47 2023 daemon.notice netifd: wgclient (22300): * Running script ‘/etc/firewall.swap_wan_in_conn_mark.sh’\nThu Nov 9 23:08:47 2023 daemon.notice netifd: wgclient (22300): * Running script ‘/etc/firewall.vpn_server_policy.sh’\nThu Nov 9 23:08:47 2023 daemon.notice netifd: wgclient (22300): * Running script ‘/var/etc/gls2s.include’\nThu Nov 9 23:08:47 2023 daemon.notice netifd: wgclient (22300): ! Skipping due to path error: No such file or directory\nThu Nov 9 23:08:47 2023 daemon.notice netifd: wgclient (22300): * Running script ‘/usr/bin/gl_block.sh’\nThu Nov 9 23:08:47 2023 daemon.notice netifd: wgclient (22300): uci: Entry not found\nThu Nov 9 23:08:47 2023 daemon.notice netifd: wgclient (22300): cat: can’t open ‘/tmp/run/wg_resolved_ip’: No such file or directory\nThu Nov 9 23:08:47 2023 daemon.notice netifd: Interface ‘wgclient’ is now down\nThu Nov 9 23:08:47 2023 daemon.notice netifd: Interface ‘wgclient’ is setting up now\nThu Nov 9 23:08:48 2023 user.notice mwan3[22602]: Execute ifdown event on interface wgclient (unknown)\nThu Nov 9 23:08:49 2023 user.notice firewall: Reloading firewall due to ifdown of wgclient ()\n
Can you connect if you put the Slate AX as a Client to the Flint as WG Server locally?
Flint (WG Server) LAN -> Slate AX (WG Client) WAN. Update the Client settings ('endpoint') to reflect the Flint's LAN IPv4 (also an endpoint, normally 192.168.8.1).
... & don't forget to change the Slate AX to a different subnet like 192.168.18.1 (GL GUI -> Network -> LAN -> Private Network -> Router IP Address).
wg show is a quick way to confirm connectivity if you can SSH. See below:
