Help WireGuard S2S VPN
Hi All, I have a Flint 2 and a Slate AX. I am trying to set up the Flint 2 as my fireguard server, and the Slate AX as the client. My objective is for my home IP to show when I work from another country. I am stuck at the stage I switch on the wireguard client - it does not come on and stays amber throughout. I have a dynamic public IP, did not need to do port forwarding.
As I am doing the set up, both the Flint and Slate are connected to the same ISP modem. Any help would be much appreciated
you can't test while you are connected to the same ISP modem. Please connect your Slate to your phone or any other internet access.
Make sure that both router have different networks. So one is OK with 192.168.8.x, but the other should be 192.168.10.x
Follow this for more details: Build your own WireGuard Home Server with two GL.iNet Routers - GL.iNet Router Docs 4
Thanks that makes sense. Waiting for USB to USB C cable to tether and test this. What about client to client vs site to site? What should I choose? I am not interested in accessing other network data, just to make my IP appear at home. Thanks
