I am switching my network, and I got this
can some one please help me with this? I know this is easy for most of you.
Thanks
Thanks
It looks like both your WWAN and LAN are on the same 192.168.8.x subnet, so routing will not work. You can change the 192.168.8.x IP addresses on the LAN webpage to something else (e.g., 192.168.18.x). The 255.255.255.0 Netmask is okay.
Thank you, worked for me.
You’re correct but this is a feature unique to gli. They just don’t like the same subnets. Routing will work as they are all on the same network BUT for some reason gli don’t. Its a bug bear for me as “parental” networks are a pain in the arse when you need constant remote and local access. Whether it has anything to do with DHCP, you can force the server off in luci, I wouldn’t know as I’ve easily bricked a gli router by messing with things it didn’t want me to mess with. So it medusa’d itself.
