Hello everyone,
I installed docker + dockerd on MT3000 (latest stable firmware) and changed the docker root dir for an external flashdrive format in EXT4. So far so good, but i tested a lot of containers and just one of then the UI works with the exposed port , but only for a few seconds: linuxserver/transmission.
I installed with default values:
docker run -d \
--name=transmission \
-e PUID=1000 \
-e PGID=1000 \
-p 9091:9091 \
-p 51413:51413 \
-p 51413:51413/udp \
--restart unless-stopped \
lscr.io/linuxserver/transmission:latest
As I said it works just for a few seconds on http://192.168.8.1:9091 and then I can’t access it anymore. No log errors, no container stopped (I can even sh the container). I don’t know what’s the problem.
Also, I tried this very simple container:
docker run -P -d nginxdemos/hello:0.2
I can’t access the exposed port, and also no errors on logs.
