Hi just bought a slate wifi 7 but cant tether
Im attaching the cables to my poco 6 pro mobile phone and to the router - nothing is happening and it says no tether device found. Please let me get this sorted its really making me regret buying this thing.
Have you enabled tethering (hotspot) on your poco phone?
Does the phone prompt a message, "trusting this computer"?
Are you using the supplied power supply?
Right, this is important.
When using a PD 3A there is no output of the USB so that the router itself has enough power.
Please use PD 9V/12V supply for Slate 7 if using the USB/tethering.
Better to use the attached power supply from the box.
The answer is use a minimum 66wat power bank ... better still 100w. They pretty cheap..!
