Hi !
Every now and then I need to reboot my GL-B3000 due to high cpu load.
I don't really have a lot of services enabled, just AdGuard Home and that's it.
Here is the output of "top":
Mem: 371204K used, 23440K free, 2268K shrd, 5808K buff, 19168K cached
CPU: 1% usr 63% sys 0% nic 2% idle 26% io 2% irq 3% sirq
Load average: 9.44 9.81 9.55 4/155 27822
PID PPID USER STAT VSZ %VSZ CPU %CPU COMMAND
9236 1 root S 688m 177% 1 24% /usr/bin/AdGuardHome --glinet --no-check-update -c /etc/AdGuardHome/config.yaml -w /etc/AdGuardHome -l syslog
7820 1 root S 1223m 316% 0 21% /usr/sbin/tailscaled --port 41641 --state /etc/tailscale/tailscaled.state
20873 2 root RW< 0 0% 1 6% [kworker/1:2H+kb]
9380 1 root S 9672 2% 0 2% /usr/bin/lua /usr/bin/gl_clients_update
20 2 root IW 0 0% 0 1% [kworker/0:1-eve]
9 2 root SW 0 0% 0 1% [ksoftirqd/0]
25185 2 root IW< 0 0% 0 1% [kworker/0:1H-ev]
67 2 root SW 0 0% 0 1% [kswapd0]
2878 1 root S 7436 2% 1 1% wpa_supplicant -g /var/run/wpa_supplicantglobal -B -P /var/run/wpa_supplicant-global.pid
Anything I should do to avoid this from happening ?
Running latest firmware version.
Thanks
