Is there any way to reduce the latency when using a vpn on the router?
I have setup the router as a WireGuard client and the lantency when I run a speed test is too high.
I am using a Mango router.
change a VPN server change a speedtest server( or change mango for debug purporse)
- Change your VPN server you are connected to
- Change the speedtest server your run your speedtest against
- Replace the router for another one
