Hostnames don't work with Adguard after update 4.6.2
Device:
Model GL.iNet GL-MT6000
Firmware Version 4.6.2
Issue:
Hostnames that were defined and working as DNS rewrites before the update, don't work after the update.
Device was running v4.5.8.
Some hostnames were defined in the Luci interface
console.gl-inet.com/cgi-bin/luci/admin/network/hosts (corresponding file /etc/config/dhcp)
ie: the default hostname for the router
config domain
option name 'console.gl-inet.com'
option ip '192.168.8.1'
After update to 4.6.2, this hostname doesn't direct to the router's "Admin Panel". Instead takes you to the following message:
You researched this page because you are not using a GL.iNet router
Adguard and DNS Settings:
(I think these are the relevant ones)
AdGuard Home
- Enable AdGuard Home ON
- AdGuard Home Handle Client Requests ON
DNS
- DNS Rebinding Attack Protection OFF
- Override DNS Settings of All Clients OFF
- Allow Custom DNS to Override VPN DNS OFF
adguardhome.config.enabled='1'
adguardhome.config.dns_enabled='1'
dhcp.@dnsmasq[0].rebind_protection='0'
gl-dns.@dns[0].override_vpn='0'
gl-dns.@dns[0].mode='auto'
"Band-aid Solutions:"
Defining under "Edit Hosts" in console.gl-inet.com/#/dnsview (or the corresponding file /etc/hosts ) fixes the issue.
ie:
127.0.0.1 localhost
::1 localhost ip6-localhost ip6-loopback
ff02::1 ip6-allnodes
ff02::2 ip6-allrouters
192.168.8.1 console.gl-inet.com
Additionally, defining it under console.gl-inet.com:3000/#dns_rewrites (or corresponding file /etc/AdGuardHome/config.yaml) seems to also solve this issue
safebrowsing_block_host: standard-block.dns.adguard.com
rewrites:
- domain: console.gl-inet.com
answer: 192.168.8.1
safebrowsing_cache_size: 1048576
Questions:
- Is this meant to work like that?
- How come the DNS rewrites were working with what was on
/etc/config/dhcpbefore the update? - Of the three places I described, which one is the proper place to define hostnames for this case?
/etc/hosts
/etc/config/dhcp
Thanks!
