I plugged my AXT-1800 into an Ethernet port at a hotel, and immediately smelled the sweet-but-unfortunate smell of Magic Smoke (the stuff that makes electronics run) and sure enough, the WAN port is dead.
What are my repair options, other than a full replacement?
(Is there a(n easy) way to turn one of the LAN ports into a WAN port?)
You should be able to do it in Luci. It’s not always possible depending on the underlying hardware, but often it is.
I haven’t tried in a while, so someone else may be able to point you in the right direction more quickly. Otherwise I can look at it when I get a chance.
I’d be interested to hear about potential causes of such an occurrence e.g. could it occur due to PoE wiring (why a hotel would have PoE I’m not sure), weaker WAN plugs or wiring in GLiNET ports / devices ?
Any other reasons for this, it’s clearly something everyone would prefer to avoid, but if a cable exists it’s also my go to for best speed Hotel Internet Access.
Cameras, Wifi Access points, conference equipment. Leave it plugged in and demand compensation, maybe things that are not labeled correctly is a fire code violation.
Yes, though indirectly. I’ve seen things get killed via a cut cable connected to a PoE switch that was shorting wires before.
To your question about why a hotel would have PoE - I can’t imagine a major hotel that wouldn’t have PoE. APs, TV boxes and phones are all easy PoE targets.
I don’t know enough about PoE but I understood power is only supplied to a device if it supports it? I guess ultimately the question is how do you reasonably take steps to prevent it happening without having to bring the kitchen sink to check it. Can (any manufacturers) Routers WAN ports be so wired / configured / designed / terminated so as to not blow up as a result?
FWIW, I’ve been plugging into hotel Ethernets for over 30 years now (and it’s sadly a dying breed as more places go WiFi-only) and this is the first time something like this has happened; it’s rare enough I’m not going to worry about it.
Just wish it hadn’t happened to my most expensive and advanced GL-iNet device
That’s the worst part- apparently the hotel wasn’t even wired for Ethernet, so I had to use the repeater anyway
Do you have instructions as to how to use one of the LAN ports as a WAN port? I’ll likely never be at that hotel again, so the risk of losing another port is fairly low.
I have people at one of my clients who are- do you think it’s just a matter of replacing the Ethernet PHY transformer?
BUT- can someone Explain Like I’m Five how to implement the change of one of the LAN ports to WAN in LuCi? And will it stick across reboots, or should I just ssh in and modify a config file somewhere?
Maybe just do this, modfiy /etc/config/network and find wan and lan.
In wan you will see one device e.g. eth0, that is the WAN port.
In lan you will find there are several devices, e.g. eth1, eth2 which are the two LAN ports.
So in wan, change eth0 to eth1;
In lan, remove eth1 from there
Do check the vlan settings etc. The idea is just to remove eth1 from lan and replace eth0 with eth1.
