Im currently using the TL-WR902AC as my travel router but im considering upgrading to the GL-AR750S-Ext.
I utilise the Hotspot mode to be able to connect to my phones Hotspot and create a new SSID connection for all my devices to connect to. This works great and all but it only allows me to configure 1 Hotspot and if I want to use my wife’s hotspot I need to manually configure it.
Does the GL-AR750S-Ext utilise a similar system where I can turn my hotspot on and create a new SSID for all devices to connect to? Also does it have the option to look for either my hotspot or my wife’s hotspot automatically? or is this also a manual process?
