How can I have IOT not use VPN? I have Nanoleaf and other and other IOT that don’t work with VPN services. How can I make a tunnel so things avoid the VPN?
You can switch Proxy Mode in the VPN Dashboard to set which devices do not access the network via VPN.
You can switch to Based on the client device, choose to specify that the device does not use VPN and enter the MAC of your IoT device.
You can also switch to Based on the VLAN. set the guest network not to use VPN and connect your IoT device to the guest Wi-Fi.
