I am totally green. I was spoiled with Tomato and DDWRT and their built-in administrative feature set that would allow me to segregate my Chinese security cameras from the internet.
Since I am completely unfamiliar with scripting or command entries, perhaps explaining what I had might help to frame my needs…
All of my WAN-enabled IPs were in the standard 192.168.1.1-254 range. Those devices which I wanted to explicitly prevent from accessing the web (or vice versa) were assigned to 192.168.2.1-254. All devices on the LAN that needed to access these cameras had a subnet mask set to 255.255.252.0 - so they could access the different octet.
Then, in the administrative section, I created a rule that blocked all WAN access to any device with an IP 192.168.2.X. It worked perfectly.
However, I do not know how to replicate this same ability with this new GL-AR750S router. Is there an easier way to block access to WAN but still allow LAN devices to communicate with them?
I could even isolate IPs within the standard range - for example: 192.168.8.1-100 get WAN and 192.168.8.200-254 are isolated from all WAN access. That would be even easier, as I wouldn’t have to change the default subnet mask.
Any help would be appreciated. While I am lazy, in this case, it is really my complete technical illiteracy that is keeping me from even knowing what to search for.
