How install openwrt packages ? For Fibocom l850 with usb adapter on GL-SFT1200
I try everything and cant install any openwrt package
for example
Unknown package ‘luci-proto-xmm’.
Unknown package ‘luci-app-smstools3’.
Unknown package ‘luci-app-atinout’.
Unknown package ‘luci-app-modeminfo’.
Unknown package ‘modeminfo-serial-xmm’.
also not possible to install install Wget-ssl omgggg!!!
This is FAKE openwrt ? I am think this is worst my buy ever because i buy this item for openwrt
for just copy/paste some commands and get everything working
This isn’t “FAKE openwrt”. Per that linked GitHub repo, you need to add the proper OpenWrt feeds to the OS via LuCI (GL GUI → System → Advanced Settings). Koshev has precompiled packages that you’re seeking in another repo.
You’d be better off directly posing your inquiry for your LTE modem module with it’s OpenWrt Linux unknown support status on there.
Good luck getting the answers you seek with that attitude though.
The SFT1200 is based on an older version of OpenWRT, and it is NOT supported by OpenWRT team, which limits what packages you can use. Several people on the OpenWRT forum have questioned GL iNet calling their firmware OpenWRT. Is it FAKE? It is definitely not official.
Other GL iNet models, like the AR300M, AR750, AR750S and the A1300 all have supported OpenWRT ports and can use the OpenWRT packages. If you need OpenWRT compatibility, you need to choose your GI iNet router wisely.
Here a post on the OpenWRT forum on issues porting to routers using the SiFlower chip-set:
Thanks, I don’t think so, I think I was deceived, and your links didn’t help me, I just need to start the modem fibocom l850
root@GL-SFT1200:/# opkg install luci-proto-xmm luci-app-smstools3 luci-app-atinout luci-app-modeminfo modeminfo-serial-xmm
Package atinout version 0.9.1 has no valid architecture, ignoring.
Package liblucihttp-lua version 2019-07-05-a34a17d5-1 has no valid architecture, ignoring.
Package luci-base version git-20.356.64372-1259bb1-1 has no valid architecture, ignoring.
Package luci-lib-ip version git-20.356.64372-1259bb1-1 has no valid architecture, ignoring.
Package luci-lib-jsonc version git-20.356.64372-1259bb1-1 has no valid architecture, ignoring.
Package luci-lib-nixio version git-20.356.64372-1259bb1-1 has no valid architecture, ignoring.
Package liblucihttp version 2019-07-05-a34a17d5-1 has no valid architecture, ignoring.
