I'm trying to setup multiple Guest networks. This is a Flint GL-AX1800.
OpenWrt 21.02-SNAPSHOT r16399+165-c67509efd7
Kernel 4.4.60
I have tried to set one up, but it wont connect to the internet. I tried to get help on the OpenWRT forums, but they said they couldn't help because GL.INET modifies the firmware.
Is there a how-to guide you can refer me to, or some other direction you can provide?
So I tried to create a guest WIFI network called "Guest1". It broadcasts, serves an IP, and I can connect to it, but it still doesn't connect to the internet. I have included the config files here, redacted of any personal data. Could someone please look them over, and tell me what I'm doing wrong?
**ubus call system board**********************************************************************************************************************************************
"kernel": "4.4.60",
"hostname": "GL-AX1800",
"system": "ARMv7 Processor rev 4 (v7l)",
"model": "GL Technologies, Inc. AX1800",
"board_name": "glinet,ax1800",
"rootfs_type": "squashfs",
"release": {
"distribution": "OpenWrt",
"version": "21.02-SNAPSHOT",
"revision": "r16399+165-c67509efd7",
"target": "ipq807x/ipq60xx",
"description": "OpenWrt 21.02-SNAPSHOT r16399+165-c67509efd7",
"tip-revision": "OpenWrt 21.02-SNAPSHOT r16399+165-c67509efd7 / TIP-devel-12b3c198",
"tip-version": "devel"
*cat /etc/config/network***********************************************************************************************************************************************
config interface 'loopback'
option device 'lo'
option proto 'static'
option ipaddr '127.0.0.1'
option netmask '255.0.0.0'
config globals 'globals'
option ula_prefix 'fd2f:7380:b714::/48'
config device
option name 'br-lan'
option type 'bridge'
list ports 'eth1'
list ports 'eth2'
list ports 'eth3'
list ports 'eth4'
config device
option name 'eth1'
option macaddr '00:00:00:00:00:00'
config device
option name 'eth2'
config device
option name 'eth3'
config device
option name 'eth4'
config interface 'lan'
option device 'br-lan'
option ipaddr '192.168.8.1'
option ip6assign '60'
option isolate '0'
list dns '192.168.8.1'
config device
option name 'eth0'
config interface 'wan'
option device 'eth0'
option proto 'dhcp'
option force_link '0'
option ipv6 '0'
option metric '10'
config interface 'wan6'
option proto 'dhcpv6'
option disabled '1'
option device '@wan'
config switch
option name 'switch0'
option reset '0'
option enable_vlan '0'
config interface 'tethering6'
option disabled '1'
option device '@tethering'
config interface 'wwan6'
option disabled '1'
option device '@wwan'
config interface 'guest'
option force_link '1'
option ipaddr '192.168.9.1'
option multicast_querier '1'
option igmp_snooping '0'
option isolate '0'
option bridge_empty '1'
option disabled '0'
config interface 'wwan'
option proto 'dhcp'
option metric '20'
config interface 'modem_1_1_2_6'
option disabled '1'
option device '@modem_1_1_2'
config rule 'policy_direct_rt'
option lookup 'main'
option suppress_prefixlength '0'
option priority '1100'
config rule 'policy_default_rt_vpn'
option mark '0x8000/0xc000'
option lookup '8000'
option priority '1101'
option invert '1'
config rule6 'policy_direct_rt6'
config rule6 'policy_default_rt_vpn6'
option invert '1'
config rule 'policy_default_rt_vpn_ts'
option priority '1099'
option mark '0x80000/0xc0000'
option invert '0'
config device
option name 'Guest1'
config interface 'Guest1'
option device 'Guest1'
option broadcast '192.168.5.255'
option ipaddr '192.168.5.1'
option gateway '192.168.8.1'
**cat /etc/config/wireless*******************************************************************************************************************************************
config wifi-device 'radio0'
option type 'mac80211'
option path 'platform/soc/c000000.wifi'
option band '5g'
option htmode 'HE80'
option country 'US'
option channel 'auto'
option hwmode '11a'
option cell_density '0'
option channels '36,40,44,48'
config wifi-iface 'default_radio0'
option device 'radio0'
option network 'lan'
option mode 'ap'
option encryption 'psk2'
option wds '1'
option isolate '0'
option hidden '0'
option ssid 'GL-AX1800-5.0Ghz'
option key '<REDACTED>'
config wifi-device 'radio1'
option path 'platform/soc/c000000.wifi+1'
option band '2g'
option country 'US'
option disabled '0'
option htmode 'HE40'
option legacy_rates '0'
option hwmode '11g'
config wifi-iface 'default_radio1'
option device 'radio1'
option mode 'ap'
option wds '1'
option isolate '0'
option ssid 'GL-AX1800-2.4'
option hidden '0'
option disabled '1'
config wifi-iface 'guest2g'
option network 'guest'
option mode 'ap'
option guest '1'
option wds '1'
option isolate '1'
option hidden '0'
option ssid 'GL-AX1800-2.4Ghz-Guest'
option disabled '0'
config wifi-iface 'wifinet3'
option ssid 'Guest1'
option mode 'ap'
option network 'Guest1'
**cat /etc/config/dhcp************************************************************************************************************************************************
config dnsmasq
option domainneeded '1'
option boguspriv '1'
option filterwin2k '0'
option localise_queries '1'
option rebind_localhost '1'
option local '/lan/'
option domain 'lan'
option expandhosts '1'
option nonegcache '0'
option authoritative '1'
option readethers '1'
option leasefile '/tmp/dhcp.leases'
option resolvfile '/tmp/resolv.conf.d/resolv.conf.auto'
option nonwildcard '1'
option localservice '1'
option ednspacket_max '1232'
option rebind_protection '0'
config dhcp 'lan'
option interface 'lan'
option start '100'
option limit '150'
option leasetime '12h'
option dhcpv4 'server'
option force '1'
list ra_flags 'none'
config dhcp 'wan'
option interface 'wan'
option ignore '1'
config odhcpd 'odhcpd'
option maindhcp '0'
option leasefile '/tmp/hosts/odhcpd'
option leasetrigger '/usr/sbin/odhcpd-update'
option loglevel '4'
config domain
option name 'console.gl-inet.com'
option ip '192.168.8.1'
config dhcp 'guest'
option interface 'guest'
option start '100'
option limit '150'
option dhcpv6 'disabled'
option ra 'disabled'
config domain
option ip '::ffff:192.168.8.1'
config dhcp 'Guest1'
option start '100'
option limit '150'
option interface 'Guest1'
**cat /etc/config/firewall*******************************************************************************************************************************************
config defaults
option input 'ACCEPT'
option output 'ACCEPT'
option forward 'REJECT'
option synflood_protect '1'
config zone
option name 'lan'
option forward 'ACCEPT'
option masq '1'
list network 'lan'
config zone
option name 'wan'
option mtu_fix '1'
option input 'DROP'
option masq '1'
list network 'wan'
list network 'wan6'
list network 'wwan'
config forwarding
option src 'lan'
option dest 'wan'
config rule
option src 'wan'
option proto 'udp'
option dest_port '68'
option target 'ACCEPT'
option family 'ipv4'
config rule
option name 'Allow-IGMP'
option src 'wan'
option proto 'igmp'
config rule
option name 'Allow-DHCPv6'
option src 'wan'
option proto 'udp'
option src_ip 'fc00::/6'
option dest_ip 'fc00::/6'
option dest_port '546'
option family 'ipv6'
config rule
option name 'Allow-MLD'
option src 'wan'
option proto 'icmp'
option src_ip 'fe80::/10'
list icmp_type '130/0'
list icmp_type '131/0'
list icmp_type '132/0'
list icmp_type '143/0'
config rule
option src 'wan'
option proto 'icmp'
list icmp_type 'echo-request'
list icmp_type 'echo-reply'
list icmp_type 'bad-header'
option limit '1000/sec'
config rule
option src 'wan'
option dest '*'
option proto 'icmp'
config rule
option name 'Allow-IPSec-ESP'
option src 'wan'
option dest 'lan'
option proto 'esp'
config rule
option name 'Allow-ISAKMP'
option src 'wan'
option dest 'lan'
option dest_port '500'
option proto 'udp'
config rule
option name 'Support-UDP-Traceroute'
option src 'wan'
option dest_port '33434:33689'
option proto 'udp'
option target 'REJECT'
option enabled '0'
config include
config include 'nat6'
option path '/etc/firewall.nat6'
option reload '1'
config rule 'process_mark'
option name 'process_mark'
option dest '*'
option proto 'all'
option extra '-m owner --gid-owner 65533'
option target 'MARK'
option set_xmark '0x8000/0xc000'
config rule 'wan_in_conn_mark'
option name 'wan_in_conn_mark'
option src 'wan'
option dest '*'
option enabled '0'
option extra '-j CONNMARK --set-xmark 0x8000/0xc000'
config rule 'lan_in_conn_mark_restore'
option name 'lan_in_conn_mark_restore'
option src 'lan'
option dest '*'
option enabled '0'
option extra '-m connmark --mark 0x8000/0xc000 -j CONNMARK --restore-mark'
config rule 'out_conn_mark_restore'
option name 'out_conn_mark_restore'
option dest '*'
option enabled '0'
config include 'swap_wan_in_conn_mark'
option type 'script'
option reload '1'
option enabled '0'
option path '/etc/firewall.swap_wan_in_conn_mark.sh'
config rule 'block_dns'
option name 'block_dns'
option src '*'
option device 'br-+'
option dest_port '53'
option enabled '0'
config zone
option name 'guest'
option input 'REJECT'
list network 'guest'
config forwarding
option src 'guest'
option dest 'wan'
config rule
option name 'Allow-DHCP'
option src 'guest'
option proto 'udp'
option dest_port '67-68'
config rule
option name 'Allow-DNS'
option src 'guest'
option proto 'tcp udp'
config include 'vpn_server_policy'
option path '/etc/firewall.vpn_server_policy.sh'
option reload '1'
option enabled '1'
config rule 'sambasharewan'
option src 'wan'
option dest_port '137 138 139 445'
option dest_proto 'tcpudp'
option target 'DROP'
config rule 'sambasharelan'
option src 'lan'
config rule 'glnas_ser'
option src 'wan'
option dest_port '6000-6002'
option dest_proto 'tcp'
config rule 'webdav_wan'
option src 'wan'
option dest_port '6008'
config include 'gls2s'
option path '/var/etc/gls2s.include'
option reload '1'
config include 'glblock'
option path '/usr/bin/gl_block.sh'
option reload '1'
config zone
list network 'Guest1'
config forwarding
option dest 'lan'
option src 'Guest1'
config rule
option src 'Guest1'
option name 'Guest1_DHCP'
list proto 'udp'
config rule
option src 'Guest1'
option name 'Guest1_DNS'
config rule
option src 'Guest1'
option name 'Block_Guest1_from_LAN'
option dest 'lan'
list dest_ip '192.168.8.1/24'
list proto 'all'
Ok, so I tried to setup a new WIFI guest network called "Guest1" by copying the existing guest network into the config files. For some reason it disables the existing WIFI network. Not sure why.
The only thing I changed was the SSID and the network IP/Range, because I want it to be a separate network.
Can someone please have a look at my config files. I would really appreciate it.
