Hi, I searched the forum but couldn't find any satisfactory answer.
the website mentions the device runs for 8 hours when fully charged?
We've got the following information from GL-E750 / Mudi - GL.iNet
| Power Input | Type-C, 5V/2A |
| Battery | Rechargeable 7000mAh Battery |
The Charging time is the capacity (7000mAh equals 7Ah) through the current (2A) ->
7Ah/2A= 3,5h
But be aware that the charging is not linear. So if you plug it out after 1,75h, the battery is not 50% charged.
For example the typical charging curve of a Li-Ion battery
lol its better to just use an android as a router then haha
it charges in less than 40 minutes and runs the same (I can install custom OS / magisk modules to make it battery efficient)
What? Android as an operating system, this does not need charging. You are right, but I am confused about this comparing.
This is just the basic math... I don't know if there is any battery killing fast charge or something like this implemented. This is based on the provided 2A power supply and maybe a 15 Watt charger will do it faster.
Just send me a GL-E750v2, and I will measure and it for you with a qualified protocol.
You are welcome to use any device that fulfill your needs. That's how using devices works, mostly.
Andriod vs OpenWrt
Smartphone vs Router
