Can you make sure the subnet is not the same as upstream router?
Yes I make sure. Subnet is 192.168.9.x but upstream router is 192.168.120.x.
It is it allowed to access the router UI.
Laptop connects to Guest wireless on GL but go to 192.168.9.1 in browser is not possible.
I do not create Guest network by use GL UI. I use Luci because no one tell me how I can create in GL UI but I ask so many times where is “Repeater section” in GL UI that is say in doc.
I know is not problem with connection because LAN wire port on GL router have 192.168.8.x and this have internet. Only wlan1 no have internet.
You can try latest testing firmware from us and you can enable guest WiFi by one click.
I already tell you I am use latest firmware! Now I ask for number one million time where is this click? I NO SEE “Repeater section” like say in doc. I tell you this so many times.
If you do this manually in luci you need to take care of the firewall as well.
Okay if you say then I will do. Please explain. I prefer use GL UI but need same informations I asking you for two weeks!
I just tested for myself, the guest network can access the Internet.
But you are create guest network by use GL UI? Me no. I want do this but no one telling me how I can do. Everyone only give me link to doc and doc only say must go “Repeater section” but not exists for me.
Okay I including firewall.zip firewall.zip (992 Bytes)
YOU NO SEE “repeater section” because you are already connected as repeater!
This not true. I think you only read some words I writing. I no have repeater. Have wireless network but not has internet. Why I need explain so many time you? I think is because you not want help only want argueing.
3.013 is latest “TESTING firmware” and I have this now two weeks. You see when I post screenshot?
I go “Wireless” tab and is blank 100%, no says anything.
I go “Internet” I can make wifi connect for modem. But not create guest network.
I go Luci I can make client wifi to modem. Also I can make guest wifi for laptop. But guest wifi for laptop no have internet. I try delete and do again with GL UI also Luci. Always same.
I try anythings you says. Please explain what I must do and I do.
I already say many time I use many different laptop for connecting. Problem not my. Problem is GL router config. I already send firewall to @kyson-lok. Existing answers inside? What you want me trying and I trying.
Did you run OpenVPN? I check the firewall configuration file, it seems you had started OpenVPN, so it missing a forward rule.
config forwarding
option dest 'ovpn'
option src 'guestzone'
Not sure what you had done, if you can reset the router to factory settings, and then do again. Please document each step and place them to here, it would be help.
config forwarding
option dest 'ovpn'
YES!!! WORKING!!! THANK YOU!!!
I have working now but you must know GL UI continue have many troubles. I do reset the router to factory settings but every problems is same. If I make WiFi client to connecting modem I will not see no options for WIRELESS, nothings completely only white page does not say nothings.
After I do this to /etc/config/firewall like you are saying and now I am see 2.4G WiFi where I click WIRELESS so I think maybe you have problems in GL UI because it not support WISP configurations if using OpenVPN.
