How to access USB share on Shield?
Has anyone managed to access a shared USB stick from a Flint 3 to an Nvida Shield?
I can see it from Win 11 or through the router's companion app but my Shield even though it sees my router as an SMB device won't let me access it with my router's admin credentials or the admin account I created when I setup SMB on the router.
Some other forum users have reported that Samba works correctly on the Nvidia Shield.
For example:
To help us narrow this down, please provide:
  • Screenshots of the Nvidia Shield’s Samba or network storage settings
  • Any error messages shown when accessing the share
It would also be helpful to confirm whether the issue occurs across different apps. Please let us know if the connection works when using third-party applications such as Kodi or VLC, as this can help determine whether the issue is app-specific or system-wide.
This was the SMB version the Flint 3 runs. Native Android was looking for SMB2 but the Flint 3 only supports SMB 3 and 4.
Some apps that support SMB 3, 4 bridge the gap like Kodi, Cx File Explorer.
It’s a bit strange, because on Flint 3 running v4.8, the minimum supported SMB version is SMB2.
It might be because encryption is required. You could try adjusting it using the following commands.
Alternatively, you could try lowering the SMB version to NT1 and see if that helps.
Of course, for security reasons, we don’t recommend doing this. If you do, please make sure it’s only used within a local LAN, or continue using third-party software that supports newer SMB versions.
