Hello everyone,
Hopefully this is a small ask but I wanted to check if users have a good way of backing up settings (not firmware) on these routers? If the model matters, I am using two GL-B1300 routers with LAN and mesh configuration.
I have reason to believe some settings may have been setup incorrect using the “Advanced” menu early on. I would like to reset and test to see if my router configuration is at fault for some port forwarding issues I am experiencing. It would be nice to be able to restore configurations if I am incorrect in my assessment.
Thanks
