A there any way to add moats? Or something like that?
Is there any GUI?
Is there any GUI?
By using the GL default firmware, it’s nearly impossible to get it working correctly and without any issues. That’s because the GL firmware is not only an additional (and easier) GUI but changes some programs and scripts as well.
Using advanced TOR hiding techniques would require to flash plain OpenWrt and then trying different ways until you found a working one. This won’t be easy, and your learning curve might be steep.
moat
seems to be only available within the TOR browser.
I like GL GUI so I don’t wanna flash plain OpenWRT… Ok, let’s submit it as FR…
