need to have access to the traffic data to send them to my Home Assistant. Where can I find them in raw format ? Browsing with an SSH and looking for folders, dont know where are.
Try F12 tools on your browser to find the API.
Wow! Thanks @alzhao, found many interesting things there. I’ll work hardly to extract the right one I need. See you soon.
Following is one of the many and many attempts made on home assistant configuration side
resource: http://192.168.8.1/src/temple/internet/api:moinfo
headers:
authorization: "Bearer "
method: GET
payload: '{ "modem" : "info" }'
username:
password:
authentication: basic
force_update: true
value_template: "{{ value_json.info }}"
json_attributes:
- 'moInfo'
unit_of_measurement: "MB"
Tried other similar http resources on Mango folders. No results in my hands.
