How to change default DNS on dhcp
Because the LAN and Wi-Fi default DNS is 192.168.8.1, I want directly use 1.1.1.1 or 8.8.8.8 at LAN and Wi-Fi.
But, I cannot change. I am using AR300m firmware 2.27, I config at “advance setting” > network > interface > lan > edit
Change “Use custom DNS servers” to 1.1.1.1
After save and apply and reboot, client only get dns 192.168.8.1
Anybody can told me how to change it
Thank you
I already get the answer at “advance setting” > network > interface > lan > edit > dhcp server > advanced setting > DHCP-Options
Change the value to 6,8.8.8.8,1.1.1.1
But what is the first vale 6?
LAN and DNS are two different things - both can be changed in the GLi UI.
Yes, don’t use Luci to change these settings. There are several places to change. Pls use GL UI to do this.
