By default, GL-iNet provides their own self-signed SSL certificate. I’d like to update this with my own self-signed cert. Where is the cert/key stored and are there any other steps required to make this work?
I obviously plan on installing the certificate to my device’s trust-store once I’m able to change that out.
I recently purchased the Slate AX. Out of the box it runs Nginx rather than Lighttpd to serve the web UI. So these instructions don’t work for this router.
Instead, I had to replace the following files:
/etc/nginx/nginx.cer
/etc/nginx/nginx.key
I was concerned these might be overwritten by a script upon reboot, but they weren’t. I’m using a free SSL cert from ZeroSSL, and it’s working perfectly thus far.
