There is no option in the fw 4.x to change USB tethering to static instead of using DHCP. Editing the /etc/config/network file manually doesnt work, the GLInet web gui always overwrites it when you disconnect and connect the USB tethering changing back to DHCP.
Can you please change this, and also is there a workaround for this?
You mean usb dongle 4g/5g? You can not change IP inside usb. I tried my usb dongle 4g and opened dongle web gui. Not possible to change IP, only insert dns IP address. So my decide to change LAN range IP in GL router.
Not sure what you mean. I want to give the usb0 tether device a static ip, of course inside the DHCP range of the 4g stick, but a static one so it is always the same.
I am logging bandwidth statistics and need the WAN device, in this case usb0/tethering always have the same IP so the statistics is properly calculated
the DHCP is buggy of the USB stick and sometimes not renew and device gets lost, so I want to set it to static with same IP
That was the question, if there is a workaround. So I should disble the teather device in the GLInet web interface and then… what? Go into Luci, set tether/usb0 to bring up at boot with static?
When I click interfaces in Luci I get this message:
