How to change wireguard port on sft100
I would like to change wireguard from the stand UDP/51820 to TCP/443. There’s no option in sft1200 UI. Any suggestions? Thanks in advance.
WireGuard does not support TCP.
Changing the port should be done inside the WireGuard server UI, see WireGuard Server - GL.iNet Router Docs 4
Super helpful. Many thanks for your assistance.
I ended up running both OpenVPN and Wireguard servers, which I was hoping to avoid, but worked amazingly better than expected. Wireguard on standard UDP for high performance and OpenVPN on TCP to get around network restrictions; OpenVPN listening on TCP/8080, but the edge firewall listens on port 443 which is PAT to TCP/8080 on the SFT1200.
The little device is amazingly! I hope others may find this info useful.
