I'm using a GL-AR750S in repeater mode, my neighbour allows me to use his wifi connection in my vacation home since I'm rarely there.
It all works great and I lvoe the GL.inet Android app but I am wondering why I can't find anywhere to check the connection quality.
The system tab only show CPU and RAM - is there maybe a plugin or Luci package I can isntall to have a quick overview of how good / stable my wifi connection is?
As far as I understand these screenshots the 5 GHz network is used for connecting to your upstream router, yep.
But bitrate of 6 Mbit/s should be some wrong display, not even sure if such low bandwidths are possible using 5 GHz. Maybe it will adjust if there is some traffic.
The second one (96.2 Mbit/s) shows the connection between you and your router.
Thanks for confirming. I guess I'll watch it for a while and if necessary switch from AUTO to 2.4GHz to connect to the upstream router and see if its better.
