I own GL-AP1300-LTE and I can successfully connect it to Verizon network. But the problem is, every time the device is rebooted, I have to do Manual Setup to get connected to LTE network.
I think the problem with Verizon SIM is that, the PDPContext 1 has to be “ims”, and the actual APN “vzwinternet” should be written to PDPContext 3. But by default, the automatic setup keeps overwriting PDPContext 1 with APN “vzwinternet”
How can I change the default PDPContext number from 1 to 3? So that every time the device is rebooted, it can get connected automatically with APN on PDPContext 3. Thank you.
PS: I know that rOOter can achieve this through its UI, is there an equivalent in the Admin Panel, or command line?
@silkweb Thank you for those links. Adding option pdptype and option profile don’t seem to work, so I guess the only option is to install the customized uqmi.
It sounds silly passing a simple parameter such as changing the APN profile and PDP type is not available as parameter on GL-iNet built-in executable or script. I would like to hear from others who may know something that I don’t
