Hello
I have the following setup:
How can I configure Flint 3 to communicate with my Server please? I tried Access Point Mode(wired), but that disables my VPN settings on Flint 3. I sometimes use VPN on Flint 3. All my connections are wired ethernet.
Thank you
Do you mean that when the VPN is enabled, PC 2 cannot access the server on the WAN side of the Flint 3?
If so, please refer to this document for configuration:
No VPN. It’s okay I found another way of doing it. I hope the Moderators can delete this thread. As it’s solved
Thank you for the clarification; we’re glad to hear the issue has been resolved.
