How do I copy a firmware of my router when the access to ssh and telnet is blocked? Dropbear isn’t running. Can I copy it with a USB to TTL ?
what do you mean “copy a firmware”?
do you mean “copy the firmware bin file to the router, then upgrade the firmware”? If yes, then the answer is yes. You can use a USB disk, copy the file to /tmp/
For example, when the file is copied to /tmp/firmware.bin, use
sysupgrade [-n -c] /tmp/firmware.bin
Maybe you want to read this first to have some options to recover your device?: 404 Page not found - GL.iNet
When you backup a custom firmware you execute this command:
cat /dev/mtd5 > /tmp/backup.bin
and you can use scp
to copy that backup to your computer, my question is what if the ssh and telnet access to my router is blocked, how can I backup my custom firmware?
Have you tried the Udisk ? The USB port is open,maybe you can try it.Good luck.
cat /dev/mtd5 > /<path-to-your-usb-drive>/backup.bin
would be nice to have a button for this in the OpenWRT GUI to make clones
Yeah,it’s a good idea.
