After upgrading OpenWRT, the MT3000 fails to boot normally. After starting it via the debrick tutorial, pinging 192.168.1.1 results in intermittent connectivity, and accessing http://192.168.1.1 via Chrome shows page not found.
Please help verify the following:
- When performing step two of the debricking guide, did you hold the reset button before powering on and release it only after the LED turned solid white?
- In step four, did you manually set a static IP address as instructed?
- Please confirm you are using the MT3000's original power supply or another adapter rated for 5V/3A.
For reference, here is the debricking guide again: What should I do if my router is bricked - GL.iNet Router Docs 4
If the device still cannot be recovered through the debrick procedure and is under warranty, please contact cs@gl-inet.com with a link to this post, your purchase channel, and your order number to request after-sales support.
After switching my browser from Safari to Chrome, I can now see the U-Boot page. Thank you so much!
