How to delete openvpn client
I entered a nordvpn for openvpn but I'm now switching to another vpn provider. How do I delete the Nordvpn entry?
Just delete the config group you created.
I didn't creat a config group. I just used the nordvpn that was showind under openvpn
Delete the account info, so that the NordVPN group will be empty.
That is also ok with other VPN provider if you did not remove the account/old profile, just import the new profile or input the new VPN provider account in the Web UI.
