I have a rsync script that runs regularly, but want to skip it when the router is connected to a detected metered wifi connection. Any ideas?
I made some headway.
In
/etc/udhcpc.user
I wrote this:
DHCPOPTS="$(uci get network.wwan.reqopts)" || uci set network.wwan.reqopts='43' && uci commit
if [ "${DHCPOPTS}" = "43" ]; then
if [ "${opt43}" = "414e44524f49445f4d455445524544" ]; then
# we don't commit here so its not saved on reboot
uci set network.wwan.metered=1
# also set dnsmasq to tell clients that we are metered
uci set dhcp.lan.dhcp_option='43,ANDROID_METERED'
else
uci del network.wwan.metered
uci del dhcp.lan.dhcp_option
fi
fi
This tells udhcpc to request DHCP option 43 - the vendor specified information tag. This is set on Android and others to signify a metered tethered connection. The output received from an Android DHCP server is ‘414e44524f49445f4d455445524544’ which is ‘ANDROID_METERED’ in hex. I also set dnsmasq to tell clients that we are on a metered connection. This appears to work on my Android phones connecting to the GL-Inet router, but not my Windows machine.
If it is found that we are metered I set a temporary uci variable interface.wwan.metered to 1.
Then in my scripts that I don’t want to run on a metered connection I run:
uci get network.wwan.metered
…if the output value is 1 I don’t run it.
If you want to use this, paste the script into /etc/udhcpc.user - this file doesnt normally exist. Then reboot your router (you may need to reboot twice) – or run:
killall udhcpc
ubus call network restart
To remove it, run :
rm /etc/udhcpc.user
uci del network.wwan.reqopts
uci commit
Then reboot your router.
This is only tested on a wireless tethered connection - It wont work as is for a usb tether or usb modem.
Great writeup!
My case is a little different, I'd like to communicate to clients that they are on a metered connection if the network traffic is over a USB LTE modem, and just stick to automatic if not.
I have an AR300M-Ext which doesn't have the latest firmware since I didn't manage to upgrade all the way there, but quite new.
Anyone know if the metered connection detection is now working as expected right out of the box, or if I would need to do something like @nopro404 did?
If so, how can I ensure that the USB tethered connection is always communicated to the clients to be metered?
