I use GL-MT300A and firmware 2.265.
How do I disable DHCP for LAN so that DNS continues to work?
DHCP relay disrupts the network because there is already another DHCP on the network.
I tried to unlink the DHCP from the LAN interface, but it didn’t help.
This should be a safer method if you have to do it again in the future:
Log into the LuCI UI and go to Network → Interfaces → LAN → Edit. On the DHCP Server tab, Check/Enable Ignore interface to turn off the DHCP server. Save and Apply the settings, then reboot the router.
