Hi, could not find kill switch option on v4 beta, need to roll back to v3, seeing this:
Isn’t the equivalent of the kill-switch located in the Global Options.
Will try, but should be able to downgrade from UI though
You can within the same firmware version. The error you saw is from OpenWRT, so a limitation there as well.
The Internet Kill Switch in firmware 3.x has renamed to Block Non-VPN Traffic in firmware 4.x
