Hi team,
I have bought a GL-MT3000 from Taobao and will use in oversea, and just noted that there is no VPN support for China version. Is that possible to enable it or flash the firmware to be Global version? Thanks!
Hi team,
@alzhao could you help? Thanks!
I have the same problem too. I need to connect to my company’s office network using OpenVPN, which was plug-and-play on MT1300, but it doesn’t work on MT3000 instead.
Can you clarify? Do you mean OpenVPN does not work or you don’t have OpenVPN?
Due to laws and regulations, we cannot provide VPN support for products sold in mainland China. Please return your product and repurchase from another e-commerce platform.
