I have a few different VPN accounts but the two I use the most often do not have reliable Wireguard option and occasionally something will work through one VPN but not the other, given my Flint has 4 LAN ports and I rarely need any more than 1 LAN (occasionally 2) for VPN. It would be extremely helpful if I could run two OpenVPN client connections at the same time with easy gl.inet GUI ability to select which LAN ports are used for which VPN connection. For Example LAN ports 1 and 2 for OpenVPN connection 1 and LAN ports 3 and 4 for OpenVPN connection 2. Currently if I want to swap between VPNs I have to login to the device, stop current VPN, select new VPN and connect - all 4 LAN ports are then used for the VPN.
I have a few fairly powerful gl.inet devices (eg Flint, Brume 1, Brume 2), even the slowest Brume 1 device can handle 'up to 97mbps' OpenVPN so has plenty of processing power in reserve even if such a feature would slow it down a little, my internet max is limited to around 50mbps and 30mbps over VPN would be sufficient anyway - is rare I'd be trying to use both VPN connections at the same time so with one simply idling the other connection should easily manage that throughput given hardware specs.
I did a basic mock up of how I'd love it to look - the same very easy to understand gl.inet GUI we're used to but with additional basic on/off switches relating to each LAN port against each OpenVPN connection (of course can only enable each LAN port for one VPN connection or the other). Would be even better if disabling a LAN port on both VPNs meant it got local non VPN internet.
I know gl.inet GUI can use OpenVPN and Wireguard at the same time but my VPN providers don't have reliable Wireguard option and I don't want to spend yet more money on new VPN providers especially given I've been using existing ones for years and good track record of them doing what I want vs unknown of trying someone new. Regardless if I did try running OpenVPN and Wireguard at the same time there's no easy GUI options for controlling what LAN ports would be using what VPN anyway.
-> In the meantime it would be useful to know just how much effort this would involve to try and configure equivalent via Luci (ie LAN1+2:OpenVPN connection 1, LAN3+4:OpenVPN connection 2) if anyone knows how and could give some pointers?, it's many years since I really played around with much networking stuff so step by step would be better! I'm sure a great many people would love to split the LAN ports up in this way.
I did see 'Policy-Based Routing' mentioned on some threads (which apparently doesn't work properly with gl.inet firmware) but that looks to be for those wanting to selectively route traffic to VPN for some specific hosts/subnets/domains which is completely overkill for what I was looking for and there must be an easier way? I just want all traffic for anything connected to LAN1+2 to use OpenVPN connection 1, all traffic for anything connected to LAN3+4 to use OpenVPN connection 2 with no interaction between the two connections (basically splitting a 4 port Flint and making it behave like two separate 2 port VPN devices).
