So Im not sure if this is possible, and if not, consider it a feature suggestion!
I have quite a few ports opened on my network now for various service, but some of them are directly related to each other, and the service will not work if just one of them is turned off. Popular example is Moonlight that uses at least 5 ports to work.
However sometimes I want to toggle one of my services, and it’s becoming tedious to toggle a group of them.
Is there a way to group together several ports with a toggle-all function?
I would recommend managing them using luci instead. There you can enter multiple ports in one rule by just splitting them using space. Within the GL UI you can only group consecutive ports by using 80-95 for example.
